UDF
Old   February 6, 2002, 00:38
Default UDF
Rahul
Hi everybody, I am trying udse complied UDF. I am using Window NT4.00 I have created very simple udfs and made all directories as per help manual instructions.
When I type nmake in build directory I get this message. The name specified is not recognized as an internal or external command, operable program or batch file.
Then when I write libudf in Flunet in Define-> User-Defined->Functions->Compiled I am getting this error
Opening library "libudf"... trying library "libudf.dll" trying library "libudf\ntx86\3d\libudf.dll" trying library "libudf\ntx86\libudf.dll" Error: open_udf_library: The system cannot find the path specified.
Can anyone help me for this. Rahul
Old   February 6, 2002, 23:37
Default Re: UDF
Greg Perkins
you have not actually compiled, due to the problem with nmake.
You need to ensure you path points to the compiler directory, where the nmake command is located.
Alternatively, type (form memory - so is not quite right, something like
\Program Files\Microsoft_Studio\VC98\Bin\nmake
This is not the right path, but if you do a find files under Windows for nmake* you should be able to determine it pretty quickly for your system
Greg
Old   February 7, 2002, 00:33
Default Re: UDF
Rahul
Thanks greg, It was problem with nmake. Now my problem is I am getting this error when I type nmake in build directory (i.e 3d), fatal error c1083: Can not include file : "stdrag.h' : No such file of directory
Is it because of wrong setting of path ?
Rahul
Old   February 7, 2002, 00:45
Default Re: UDF
Greg Perkins
Not sure. You need to follow the Fluent directions exactly when using Windows. ...I know its not that clear, because I had to do it once...personally I prefer unix/linux if there's a choice.
Looks like a path problem, but can't be sure. Did you try just from the command line like I suggested??
Greg
Old   February 7, 2002, 02:35
Default Re: UDF
Rahul
Hi greg, I have given correct path for nmake. Now I am not facing problem becuase of nmake but I think becuase of compiler for c/c++. Shall I reload visual c++ with set path atomatically option ? In my computer paths for others are not created. I think it could be a reason. Rahul
Old   January 3, 2014, 09:38
Default udf
Gokuldas M
gokulgech is on a distinguished road
i am using windows 8, 64-bit. Pls sugest how to set path and environment also which Microsoft visual studio and sdk to instal
Can anyone help me for this. gokul[/QUOTE]
thank you
Last edited by gokulgech; January 4, 2014 at 01:08. Reason: i am doing M Tech project using ansys fluent
gokulgech is offline   Reply With Quote
Old   January 4, 2014, 21:30
shuai_manlou's Avatar
CAO Liushuai
shuai_manlou is on a distinguished road
First of all, what is the edition of your Flent and your Visual studio ? Fluent 12,13 and 14 requires visual studio 2008 to 2012.
Second, you should set your computers enviroment correct. You can search the nmake.exe in your computer, and copy the path to the enviroment variables.
It is done.
shuai_manlou is offline   Reply With Quote
Old   January 6, 2014, 07:59
Default udf
Gokuldas M
Ansys 14.5>flent 14.5
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
