periodic flows
Old   February 18, 2002, 08:58
Default periodic flows
Phil
can periodic flows be used to model angled vanes? I have a tube which contains 12 angled vanes which are used to create swirl. Can I model a 1/12 segment of the cylinder and set the segment planes as periodic boundaries. The fluent manual says that for periodic flows the geometry must be translationally periodic. I would describe the situation as rotationaly periodic, does this matter?
Old   February 18, 2002, 10:04
Default Re: periodic flows
Jonas Larsson
Yes, you can model this easily in Fluent - Mesh your domain with two identical periodic faces and define them as walls initially. In Fluent first specify your rotational axis of the fluid domain (in the boundary condition panel) and then use the text interface to create the rotationally periodic interface with /grid/mofify-zone/make-periodic
Old   February 18, 2002, 10:59
Phil
Thanks for that Jonas, it dosn't seem to be working but im not entirely sure that the face meshes are identical so I will try that first. Is this generally a better strategy than linking the face meshes and creating periodic boundaries in Gambit?
Old   February 18, 2002, 14:09
Jonas Larsson
The faces meshes must be identical and you should link them in Gambit. However, there used to be a bug in Gambit which broke things if you defined the faces as periodic already in Gambit - this might have been fixed now but defining them as walls has always worked for me so I'll stick with that.
If you have problems to get all nodes to match you can increase the matching tolerances slightly inside fluent with something like
/grid/modify-zone/set-tolerance
You should not need to increase it a lot - then something is wrong with your grid. Another reason for failing to make the faces periodic in fluent is if you have not set the rotational axis.
Old   February 20, 2002, 01:32
Philipp Beierer
I think that "Gambit-periodic bug" has been fixed a while ago as I used this feature successfully. At least since release 1.2 and later I hadn't any problems with it...
Old   February 20, 2002, 03:47
Phil
thanks for the help so far, I am still having problems now when i check the grid i am getting messages like
WARNING: node on face thread has multiple shadows.
What does this mean?
Thanks in advance
Old   March 5, 2002, 07:52
Volker Pawlik
You get this warning if a thin wall (i.e. a two sided wall) hits on a periodic boundary. Then Fluent warns for multiple shadows.
Ignore the warning for this case.
Volker
Old   March 5, 2002, 08:07
lhb
You should define the rotation axis of fluid in boundary condition if it not is Z.
Old   March 19, 2002, 13:31
Zahir
i have a similar geomtry set-up for a combustion chamber, What I would like to know and may also apply to phil, is that once i have a 60 degree segment of swirling flow with periodic boundaries can i use fluent to give me a particle track for the full 360 degrees to see the particle progress through the full chamber. Thankx
Old   March 20, 2002, 05:26
Volker Pawlik
In the new manual of fluent 6.0 chapter 5.6 p.5-41 I found s.th concerning duplicate shadows:
for coupled walls you can repair them by: grid/modify-zones/repair-duplicate-shadows
for periodic-bc: grid/modify-zones/repair-periodic
Old   March 20, 2002, 06:01
  #11
Phil
Yeah it is possible
Display/views then set the number of periodic repeats you require 5 in your case.
Old   March 31, 2002, 23:01
  #12
david
"NO" Displaying the 360 degree view will show the same particles track 6 times, not the actual particle track.
DC
Old   May 16, 2013, 03:09
Default periodic flows,repeating in time or geometry?
  #13
soodabe
borhan_sd@yahoo.com is on a distinguished road
I am modeling a respiratory mask for adsorption of air pollutants,because the act of respiration is not continuous at the time I thaught that I should use periodic flow model in Fluent,But after studing the user guide I saw that apparently in this models the flows should be repeat with geometry of our system not with the time ,Is it right?
Shall i use periodic flows model or not?
Help me please.
borhan_sd@yahoo.com is offline   Reply With Quote
Old   May 16, 2013, 04:44
OJ
oj.bulmer will become famous soon enough
Yes, the term "periodic" here refers to the geometrical periodicity, ie - if the actual geometry is such that the actual fluid domain in the simulation repeats itself.
For your case, you can of course model the flows that are periodic with time without using the periodic boundary conditions of course since your respiratory mask doesn't have repeating patterns of geometry. However such transient simulations are tricky to model you will need to do a lot of homework before venturing into it.
OJ
oj.bulmer is offline   Reply With Quote
Old   May 16, 2013, 07:21
soodabe
OJ
Hi,you mean that in spite of the expression "The geometry must be translationally periodic" in the 9.2 section of user giude about limitations of model,I should enable this model?
Isn't there another part in the fluent for periodic time flows?
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 02:18
problem about periodic boundary condition in Fluent winnawinna FLUENT 0 December 28, 2010 23:32
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 02:39
under relaxation & Periodic Flows Ardalan Main CFD Forum 4 April 18, 2010 00:43
periodic flows and heat transfer? scarecrow FLUENT 3 December 2, 2003 00:59
