injector with fluent
Old   February 19, 2002, 13:18
Default injector with fluent
mehdi icho
how can we define an injector with gambit or fluent thank you
Old   February 20, 2002, 05:56
Default Re: injector with fluent
Jin-Wook LEE
Which material are you going to inject ?
1. For gas : Injection area should be generated at the mesh generation level(Gambit). That is, each injector should be defined as surface.
2. For oil and solid : Injection can be defined at the point, group or surface. This is defined at the solver level(Fluent). See 'define injection'.
Sincerely, Jinwook
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
