turbulent model
Old   May 2, 2002, 15:35
Default turbulent model
yong
Could sb. tell me which models the FLuent provided can be used to calculate the flow at low Re# ?
thanks
Old   May 2, 2002, 21:46
Default Re: turbulent model
zahid
if u pl! tell the range
Old   May 3, 2002, 17:21
yong
Re around 5000
Old   May 6, 2002, 13:33
zahid
Standard k-e, RNG k-e: if u have non-equilibrium wall functions R: k-e for high Re and 2 layer model RSM: complex swirling flow LES: For fundamental turbulent studies
Old   May 6, 2002, 22:36
yong
thanks
Old   June 6, 2002, 09:41
lingo
Hi:
Which is the appropriate turbulent model for a small centrifugal pump (n=3000rpm,incompressible fluid)
Low Reynolds number k-E Turbulent Model Sohail FLUENT 19 July 16, 2020 14:08
flat plate with turbulent model danielcebrian OpenFOAM 10 November 13, 2014 15:47
LamBremhorst turbulent model J0bouchard OpenFOAM 3 February 21, 2013 09:28
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 12:00
Turbulent SST model fergal CFX 13 November 2, 2010 18:15
