outflow boundary condition control
Old   May 6, 2002, 12:40
Default outflow boundary condition control
Hua Gu
hi, everyone. I am running a case with one inlet but two outlets. The thing is that how should I set the flow rate weight, since I can not tell how much of the percentage of inflow will go through one specific outlet. What should I do? Thanks in advance.
Old   May 6, 2002, 16:11
Default Re: outflow boundary condition control
Chetan Kadakia
What do you know about the 2 outlets? if you know pressure to which the flow is exiting to, you can define pressure outlet conditions. If you know velocity, you can define inlet conditions with flow leaving the domain.
Maybe you guess at the exit pressure(s) and then find out how much mass exits one are and how much the mass exits the other. Then run the solution with 2 outflow bc's and the corresponding flow rate weighting.
Or maybe you can estimate it with simplifications. That depends on your type of flow.
Old   May 7, 2002, 18:21
Default Thanks very much
Hua Gu
Old   May 8, 2002, 11:19
Chetan Kadakia
Could you tell me what is that you have decided to do, and what kind of problem you are solving for?
outflow boundary condition foe flow over a cylinder Ardalan Main CFD Forum 0 April 29, 2010 13:04
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
outflow boundary condition Maziar Mahzari CFX 0 May 8, 2006 03:23
Zero outflow boundary condition sk Main CFD Forum 2 February 12, 2006 23:21
The Boundary Condition about the Flat Plate boing Main CFD Forum 1 January 6, 2002 16:53
