Discrete phase or two phase model in Fluent?
Like Tree1Likes
  • 1 Post By helix
Old   July 16, 2002, 10:50
Default Discrete phase or two phase model in Fluent?
andrea panizza
Good morning, I am a Ph.D.student working in the field of CFD, who used to code his own programs for CFD analysis, until now. I should model the flow of an ideal gas around and into an instrument for the measurement of dust properties (that is, a fairly complex 3D geometry), and the transportation of dust by the flow, as well as its interaction with the instrument. Ambient pressure is around 6 mbar and temperature is around -40 °K; the dust content is 1.8e-7 kg/m^3 (mass of dust per unit volume of gas). The dust radius is exceedingly small, e.g. of the order of microns: the characteristic length of the instrument may be taken to be 4-10 cm. I would like to use Fluent to simulate this problem: how can I choose between a two phase model and the discrete phase model? Any suggestions? Thanks,
Andrea Panizza
Old   July 17, 2002, 15:51
Default Re: Discrete phase or two phase model in Fluent?
Newbie1
As I understand you have only the gas and the dust, so a single flow solver and DPM should suffice.
Cheers
newbie
Old   July 17, 2002, 20:30
Jin-Wook LEE
And I think that you do not need to consider the 'interaction with continuous phase' because the mass flow rate of discrete phase is so small.
Sincerely, Jinwook
Old   November 17, 2009, 21:43
Default I have problems about CFD model of downdraft gasifier
Wang Long
wanglong is on a distinguished road
Originally Posted by Jin-Wook LEE
;101770
Sincerely, Jinwook
Hello, Mr. Lee Jinwook,
I am a Master student study in biomass gasificaion in Korea. I am trying to make a CFD model of downdraft gasifier using FLUENT 6.3. I have a lot problems. I am not sure if you can see my message and give me some advise but I hope so.
I tried 2 ways to simulate this gasification process: one phase and multiphase.
In one phase case, wood determined as very small carbon particles. So the carbon particles and air determined as fluid phase. The details you can see in the fluent case file. The model was run in a computer which has 3G RAM and Q6600 cpu for more than 12 hours and iterated about 26,000 times.
The problem is:
1.The simulated result presented that nearly no reactions occurred in the gasifier.
2.If I use a injection of wood inlet, the injection rate will be very small because the wood is drop down very slowly, I cannot simulate the right case use a injection.
In 2 phase case, carbon determined as solid phase and details of model setting as below:
The problem is :
1.In the simulated result, temperature is too high (highest is 5000K), the temperature range in experiment is from 293K~1600K.
2.No reactions occurred in the gasifier as the simulated results.
**Setting of Multiphase (2 phase)
Slover
Slover -Pressure Based
Formulation -implicit
Space -3D
Velocity Formulation -Absolute
Gradient Option -Green-Gauss Cell Based
Porous Formulation -Superficial Velocity
Multiphase
Multiphase Model -Eulerian
Number of phase -2
Energy
-Energy Equation
Viscous Model
Model -k-epsilon (2 eqn)
k-epsilon Model -Realizable
Near-Wall Treatment -Standard Wall Functions
k-epsilon Multiphase Model -Mixture
Model Constants
C2-Epsilon: 1.9, TKE Prandtl Number: 1, TDR Prandtl Number: 1.2, Disperion Prandtl number: 0.75, Energy Prandtl Number: 0.85, Turb. Schmidt Number: 0.7,
Species Model
Model -Species Transport
Reactions -Volumetric & Particle Surface
Options -Inlet Diffusion & Diffusion Energy Source
Turbulent -Chemistry Interaction -Finite-Rate/Eddy-Dissipation
Operation Condition
Pressure: Operating Pressure(pascal)-101325
Gravity: Gravity- Gravitational Acceleration Z(m/s2)=-9.8
Boussinesq Parameters: Operating Temperature (k)=288.16
wanglong is offline   Reply With Quote
Old   November 6, 2010, 04:22
Default Fluent Vc++ Programer
zhangzhiyan
zzyan is on a distinguished road
is anyone have a software of Fluent Vc++ Programer?
can u share it for me
xjzzyan@sina.com or qq:349134327
thanks
In learning and straightway practising is there not pleasure also? When friends gather round from afar do we not rejoice? Whom lack of fame cannot vex is not he a gentleman?
zzyan is offline   Reply With Quote
Old   November 6, 2010, 06:50
k.baker's Avatar
Khalid Baker
k.baker is on a distinguished road
use C++ builder its small program from C++ for making texts
k.baker is offline   Reply With Quote
Old   March 14, 2011, 03:25
Default Querries about Discrete phase model
Sumer
s567d is on a distinguished road
Droplet evaporation;heat and mass transfer;two way interaction; coaxial fuel and air flow; known air velocity and fuel mass flow rate;
1) How can I model for a fuel which is not in the list of fluent (say, Iso-propyl alcohol [IPA])? If the fix is not regular.
2) I want to use UDF for heat and mass transfer. Can any one tell where to add udf. No option is available on my software or am I doing wrong?
3) Can I know the droplet phase velocity, diameter, temperature, etc., other than droplet trajectory. Also, droplet extinction time or evaporation rate. Then, How? I not able to get any DPM info other than droplet trajectory. Also the message from fluent was that Heat and mass transfer is incomplete.
s567d is offline   Reply With Quote
Old   October 9, 2011, 04:38
Default another flow in mass flow inlet
amir
amirmohebbi is on a distinguished road
dear all
hi
I am new in fluent
how i can define all of my mesh zone stagnation air
and mass flow inlet another flow like that fuel
then i have to the mixing rate of them
please help me?
thanks for your attention
amir mohebbi
amirmohebbi is offline   Reply With Quote
Old   May 13, 2013, 03:08
soodabe
borhan_sd@yahoo.com is on a distinguished road
Hi,Is a fixed bed of an adsorbent(with high surface area) for adsorption of air pollutants a Discrete Phase Model in fluent?
Our pollutants in air are vapors.
borhan_sd@yahoo.com is offline   Reply With Quote
Old   May 13, 2013, 07:01
Sumer
I Think, DPM model wouldn't be appropriate. You may also try COMSOL software, if needed.
Old   July 19, 2013, 06:33
Default droplet modeling
  #11
mehran
helix is on a distinguished road
hi to all.
i want to modeling a liquid liquid direct contact heat exchanger and in this model i have 2 phases one of them is continuous phase and the other on disperes phase( group of droplet) and when i want to inject droplets from disperes surface all of the option related to particl type are off and i dont now why?somebody help me?tahnk u
fluent: define> model > disceret phase> injection >
bilel likes this.
helix is offline   Reply With Quote
Old   July 19, 2013, 06:51
Ivan Telnov
Gerim55 is on a distinguished road
Originally Posted by amirmohebbi View Post
dear all
hi
I am new in fluent
please help me?
amir mohebbi
I think, you should work with multiphases models and 'Solution initialization - volume fraction'.
But it depends what multiphase model is appropriate for you or/and what one you've chosen and what is you study purpose?.
Can you show picture of your model or explain your case of study in detail?
Gerim55 is offline   Reply With Quote
Old   July 19, 2013, 08:42
Sumer
Originally Posted by helix View Post
hi to all.
Check if species transport is ON.
Old   January 8, 2015, 02:02
Jitendra
Jitucj is on a distinguished road
Hi..I am Research Scholar and I am doing the CFD study of preparing an emulsion solution but I could not find it on FLUENT 6.3.26 can any one help me regarding this? I tried this on Discrete Phase Model but did not get it perfectly. So please help on this.
Jitucj is offline   Reply With Quote
Old   September 6, 2015, 16:18
sepideh
sepideh55 is on a distinguished road
Hi. I want to simulate the dust explosion in a tube. the general picture of my work is as follow. we put some concentration of dust on a plate and air with high pressure(7 bar) enters the tube. so the particles of dust start to desperation. after a certain time spark ignition ignites and the reactants starts to burn. I want to know if should I consider DPM for dispersion of dust? if yes, which kind of the injection should I take into account?(surface, single, cone,...)?
sepideh55 is offline   Reply With Quote
Discrete Phase Model vittal FLUENT 4 October 28, 2014 10:07
discrete phase model venu FLUENT 4 December 28, 2011 06:52
Discrete Phase Model on liquid Rodrigo FLUENT 3 June 3, 2004 10:52
Settling Velocity - FLUENT Discrete Phase Model Lily FLUENT 2 March 6, 2002 21:44
discrete phase in turbulent flow using fluent ursenbacher Main CFD Forum 0 January 5, 1999 11:25
