[UDF]How to get flow variables at specific coords?
Old   July 17, 2002, 09:58
Default [UDF]How to get flow variables at specific coords?
Mickael PERRIN
I would to get flow variables in UDF at specific coordinates. However I only see functions like C_V(c,t) or C_P(c,t) which required the cell and thread pointers.
So it is possible to know the cell and thread pointers with physical coordinates?
The only one solution I see for instance is to do a loop over all cells on the domain and to test their coordinates... I am not sure of efficiency
So, any ideas are welcome.
Thanks
Mickaël PERRIN
Old   July 18, 2002, 15:11
Default Re: [UDF]How to get flow variables at specific coo
Lanre
There might be an efficient way if we knew exactly what you are attempting. However, the only way I can think of is to loop to match the x, y, z location with the variable. If you can create a surface in your original mesh, i.e. so a thread ID exists for it, you could minimize the search time by focussing the search on that surface ID.
Old   July 18, 2002, 15:25
Mickael PERRIN
Thanks for your answer !
In fact, my main goal is to export data at specific location in all data files. I want to draw the pressure, speed,etc.. at specific locations in function of time.
I know how to do the loop over all data files. However, i have no idea of an efficient way to write into a file the pressure, speed at specific locations!
I hope this help you to find an efficient way !
Thanks again.
Best regards.
Mickaël PERRIN
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
