How many time steps should I use?
Old   July 19, 2002, 00:09
Default How many time steps should I use?
Dhananjay
Hello all,
I am simulating an unsteady, laminar flow in Fluent. I have determined the smallest time scale and am using a time scale which is 1/10th of this as my time step. How do I determine the number of steps that I need though? Is this based on the residence time of the fluid (I have flow in a channel with obstacles in it- so must I take length of channel/velocity as my total time to get an accurate solution?)
Thanks. Dhananjay
Old   July 19, 2002, 09:20
Default Re: How many time steps should I use?
Laika
--make sure you have good initial conditions (e.g. from a steady calculation)
--choose a time step as such that you have a large residual-drop within each time-step in 20-30 iterations per time-step.
--leave it running
good luck,
Laika, still orbiting
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
UDF for time steps David FLUENT 0 August 14, 2007 11:54
Time steps - Large Eddy - LES Gernot FLUENT 0 September 14, 2005 11:54
