October 8, 2002, 08:02 |
PRINT VALUE FROM UDF
Hi I am using UDF for the momentum exchange terms using DEFINE_EXCHANGE_PROPERTY for multiphase flow.I want to print the value of these interaction term calculated by UDF. Plz Help.
October 8, 2002, 08:55 |
Re: PRINT VALUE FROM UDF
use Message("text"); in a compiled udf
October 8, 2002, 09:05 |
I am using INTERPRETED UDF then how to print calculated by UDF.
October 8, 2002, 09:18 |
printf ?
or compile it ! |
October 9, 2002, 01:23 |
hi It is printing continuously for all the time steps but i want to print it only once just to cross check it with hand calculation.
October 9, 2002, 01:53 |
It is printing each time the udf is called e.g. in each cell, which is whath you asked.
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
DEFINE_DPM_OUTPUT macro UDF HELP | Puneet | FLUENT | 3 | November 28, 2003 10:55 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
