Fluid / Particle Interaction
Old   October 9, 2002, 09:14
Default Fluid / Particle Interaction
Alex
Hi! I have a (hopefully trivial, at leat for someone out there) problem: I am trying to simulate the acceleration of abrasive particles (garnet) in a high velocity fluid stream. I have a pressure in- and outlet and a surface particle injection (fluid/particle interaction switched on). The problem is: After iteration, the particles have in every position exactly the same speed as the fluid, so that they appear not to have any inertia. What am I doing wrong? Thanks in advance, Alex
Old   October 10, 2002, 05:40
Default Re: Fluid / Particle Interaction
Vaibhav
hi i think u should try the fluid inlet and a solid inlet(high density fluid in eulerian- eulerian grannular model ) instead of the surface particle injection. that may help u . beacuse in surface particle injection solid behave as inerts. so they acuire same velocity as that of fliud.
Old   October 10, 2002, 10:49
CFD Newbie
Have you turn on gravity ( a must)?
What is the density of your particles?, if small, inertial effects are not present.
Is your particle tracking in unsteady state?
Have you tried particle-flow interaction?
All these factors have an impact on the behavior of your particle tracks. Try all of them.
Cheers
CFD Newbie
Old   October 11, 2002, 05:53
zahir
I am looking into moddeling a similar flow. I want to model diesel exhaust flow with very many different constiuants. is this possible in fluent. Any ideas. Thanks
Old   October 21, 2002, 12:21
Sreedhar
Alex:
Your particles will have have more or less the same velocity as the fluid if the particle size and/or density is very small (in this case fluid inertia dominates the particle inertia)and if the number of particles is not large enough to consider a 2-way/4-way coupling of the multiple phases.
Also, as you would have observed, (for a 1-way coupling) the particles will follow the fluid streamlines all along unless there is any solid obstruction in their path. Hope this helps.
Fluid Structure Interaction fw407 OpenFOAM Running, Solving & CFD 9 February 14, 2013 17:25
Transient analysis of particle flow with Fluid-Structure Interaction (FSI) Julian K. CFX 2 September 15, 2011 15:30
ANSYS problem in solving fluid fluid interaction Fayyaz CFX 0 July 24, 2006 09:03
interaction time between particle and eddies Steve FLUENT 0 April 10, 2001 18:17
Big particle interation with fluid in DPM olivia FLUENT 1 January 15, 2001 04:32
