time steps in LES
Old   October 14, 2002, 09:41
Default time steps in LES
Jimmy
could someone give me a good method to set a correct time step in LES simulations. The only infos given by the manual says : "under 20 iteration to converge"
i'm not sure this is a good argument to put in a scientific work
I've tried using a CFL condition witch could be interpreted as : "the information cannot jump to the next cell during one time step" but the CFL conditions given in the manual refers to the coupled solver and i use the segregated one.
any idea ?
Old   October 14, 2002, 10:07
Default Re: time steps in LES
fb
You can just consider the max. streamwise velocity and the smallest cell size in the same direction to evaluate a time step (this will be cfl~1).
For exemple channel flow with streamwise x direction with vmoy ~1 and DeltaX =0.01 => Delta t= 0.01 ....
Old   October 14, 2002, 10:44
Jimmy
that's what i'm actually using, while adapted after some readings to CFL=0.3
but this is true only for stability in explicit time integration, is there a good justification for this in an implicit second order time integration ?
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
UDF for time steps David FLUENT 0 August 14, 2007 11:54
LES - Time Steps, Iterations Gernot FLUENT 0 August 26, 2005 13:13
