October 21, 2002, 07:56 |
multiphase jet
Hello
i try to simulate a water jet flow in a tube but it doesn't converge. I use the VOF model and the time step is 1e-6. the water can't come in the air tube. does somebody have already studied a such flow? Nicolas |
October 22, 2002, 09:25 |
Re: multiphase jet
What type of VOF did you use? Whats the BCs at the edge of receiving cylinder? Type of mesh? DC
October 22, 2002, 10:58 |
Re: multiphase jet
I first use the VOF with Geo constructor.
Then i use the mixture model with the slip velocity option. When i use fuel in a water tube, both methods converge but the time step selected by the time adaptive is very smaller with the VOF (1e-5 after some iterations) than with the mixture model (0.1s after some iterations). At initialization, the time time is 1e-4 but when i use water (or fuel) in a tube full of air, the VOF doesn't converge. the geometry is a 2d'one. It consist of a small tube connected to a bigger one As BC, i impose : inlet of the small tube velocity: 1 m/s fraction volume 1 turbulence intensity and diameter inlet of the big tube atmospheric pressure outlet atmospheric pressure the mesh is hexahedral without boundary layer but the mesh is raffined near the connection of the tubes Nicolas |
Jet fan and Tunnel simulation | ahlo7 | CFX | 9 | November 13, 2019 04:54 |
2D Plane Jet Fluent Solution | doug | Main CFD Forum | 11 | February 4, 2019 09:34 |
Multiphase flow (Comp. jet of gas into liquid) | Sarah | FLUENT | 1 | October 7, 2013 21:39 |
determination of jet front | Fred | CFX | 5 | February 11, 2007 12:01 |
IMPINGING JET ........... HELP!!!!!!!! | Amir Omoumi | Main CFD Forum | 10 | August 30, 1999 22:11 |
