meshing Pebble bed using Gambit
Old   February 12, 2003, 14:08
Default meshing Pebble bed using Gambit
Maergaret
I need help meshing a pebble bed. I tried using size function but get an error message that volume meshing fails due to smaller areas between the volumes. How can I go about this?
Old   February 15, 2003, 15:10
Default Re: meshing Pebble bed using Gambit
Startup
Hi...
How are you planning to model the pebble bed? I am also modeling something similar to a pebble bed. It would be good to exchange some views on that.
Old   February 16, 2003, 10:16
Erwin
You are creating a tangent point where pebbles touch each other. This is very hard to mesh properly with reasonable skewness. I would probably use a tet mesh (against my normal practice) and make sure I have a sufficiently fine mesh at the pebble contact points. This could mean a very large number of cells!
Another option could be to eliminate these tangent points by flattening the pebbles a tiny little bit at the contact points.
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
