February 16, 2003, 20:47 |
how to display stream function?
I don't know how to display stream function in Fluent? Can you tell me ?
February 17, 2003, 00:45 |
Re: how to display stream function?
Go to Display--> contours--> velocity then in the second drop down list....select stream functions and then click display ok
February 17, 2003, 00:59 |
prasanth,there is not stream functions in the second drop down list.
February 17, 2003, 01:08 |
the version do not include this !
February 17, 2003, 03:37 |
hello zhuang, if u r using fluent 5.x or 6., then definetly there will be the stream function option in the second drop down list with velocity in the first drop down list. tell me which version u r using?
February 17, 2003, 05:03 |
Hello guys, the stream function is only available in 2D!
February 17, 2003, 06:01 |
you are right Erwin, zhuang's problem may be 3D. I too forgot to ask him assuming his problem as 2D
February 17, 2003, 23:29 |
Thank all of you!My problem is 3D.Can I get stream function in other post-process software?
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
