Can Fluent do this?
Old   March 18, 2003, 14:47
Default Can Fluent do this?
Srinivas Kothy
Can Fluent or any other CFD package simulate a refrigerant flow(phase changes when it goes thru evaporator and condenser) in a heat pump setup?
We have a test facility here. We would be very interested in computer simulations of the set up
Thanks Srinivas
Old   March 19, 2003, 01:32
Default Re: Can Fluent do this?
Boris
There is no way to simulate the whole system in one model. But, it may be possible to separately simulate the flow process in the main components of the refrigeration system. Even so, the size of each model may be huge, depending on the complexity of your system. Good luck.
Old   March 20, 2003, 03:50
Chetan Kadakia
I think fluent is lacking in its phase change capabilities, but there must be other code out there that can do this. I have several years of experience in refrigeration, and am an expert in the field (supermarkets and some industrial refrigeration systems).
I am intrigued and would like to know more of your testing, if you are at liberty to talk about it.
Email me at your convenience.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
