Artificial Viscosity
Old   March 19, 2003, 09:19
Default Artificial Viscosity
sile
I have noticed some strange effects in my total temperature and I believe it may be due to the effect of artificial viscosity introduced by the solver. I was wondering if anyone out there has had a similar experience or could give me some pointers on this. Thanks!
Old   March 20, 2003, 02:57
Default Re: Artificial Viscosity
Chetan Kadaki
Please explain what artificial viscosity you are referring to? I mean, what is modeling the viscosity, and why is it unrealistic.
Give more details to your problem, then there will be more to discuss.
Old   March 20, 2003, 05:34
sile
thank you for your comments, I am relatively new to CFD so I'm probably asking something quite obvious! I am modelling compressible flow, of air from a volume/atmosphere into a bellmouth ended pipe. I was expecting to see little or no heat transfer and as a result was expecting my total temperature to remain fairly constant. This is the case with the segregated solver but with the coupled solver I get an unexpected temperature variation, not only is it larger than expected it is also in a region where the bellmouth should have no influence. I have been trying to get to the bottom of it unsuccesfully. Artificial viscosity was suggested to me as a possibility. As the approach to linerizing and solving the discretised equations is different in the coupled and segregated solvers, I thought this odd behaviour might be a product of the numerical method. I'm quite stuck on this and would appreciate if you could give me any advice! Thanks
Artificial Viscosity Luiz Eduardo Bittencourt Sampaio Main CFD Forum 12 November 13, 2011 10:21
Artificial Viscosity MAB CFX 1 July 30, 2008 22:00
Artificial viscosity rads CFX 2 July 31, 2006 07:02
artificial viscosity rvndr Main CFD Forum 1 March 2, 2004 10:24
Artificial Viscosity Girish Bhandari Main CFD Forum 5 January 13, 2001 13:22
