March 20, 2003, 23:42 |
about udf
Dear friends I am using Fluent for my project. I am doing "computational analysis of flow through diffusers for a centrifugal compressor". I am doing 3D analysis. I need to specify the components (Tangential and Radial) of inlet (of diffuser) velocity as a function of z (Vr = Vq = f (z)). So I have to write an UDF. So, can you please send any example which will guide me to write that UDF as early as possible. thanks in advance
March 25, 2003, 03:03 |
Re: about udf
Did u read the udf manual or do u have that one? if not then mail me at the above address I can send to u.
Alamgir |
March 26, 2003, 00:09 |
Re: about udf
Dear Madhu,
Check the udf again, it is also for the 3D problem. U have to convert the equations from Cylindrical to Cartetian... and then u can access a component of a gradient vector by specifying it as an argument in the gradient vector call (0 for the x component; 1 for y; and 2 for z). eg: x=x[0]; y=x[1]; and z=x[2], if u carefully see the examples u will get it. bye Alamgir |
March 26, 2003, 06:28 |
Re: about udf
Dear Alamgir thanq for u r response. i will try for .that
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
