Automating Fluent Results output
Old   April 30, 2003, 07:06
Default Automating Fluent Results output
Rajil Saraswat
I think this question must have been already addressed before, but the search on the forum did not result anything , os here it goes again.
Is there a way to automatically save results to a file after certain number of iterations? I want the results to be stored in a file after a fixed interval. Moreover i also want the contour plots to be saved as images, is it possible to automate this.
Thanks a lot.
Old   April 30, 2003, 07:23
Default Re: Automating Fluent Results output
beginner
File-Write-Data, you can save the document. Put the mouse on the plot, press right button, choose "Copy to Clipboard".
Old   April 30, 2003, 11:20
Rajil Saraswat
Thanks. I am beginner on fluent and learning thing slowly. Is there a way to also save contours as images along with the autosaving of data file? If there isny any straight way, can a separate program do this? Greetings.
Old   April 30, 2003, 11:53
mateus
HI
You can auto save case and data every ?? timesteps/iterations. To get images it's the easyest to go to solve-animation-define.... After finished calculation you can store the images as mpeg, tiff, eps, jpg....
regards MATEUS
Old   April 30, 2003, 12:46
beginner
Read-Case&Data, then Display-Contours.
Old   April 30, 2003, 13:44
Rajil Saraswat
This doesnt automate the things. I will have to do this manually,Read Case >Data for all the files, and then save images. On the other hand i was looking for a way to automate this stuff. A program which can read these data files and output images.
Thanks
Old   April 30, 2003, 17:08
Vladimir Krejci
Hi
you can make use of journal file first you record your actions into that file and then run it Record is quite straightforward
:file>write>star journal do what you want the journal to do
:file>write>stop journal after this sequence look at the journal file if you need (as you need) edit it
to run the journal
:file>read>journal
I hope it helps a bit
Old   May 21, 2003, 02:35
jieremy
hai! i think u can make full use of the scipt of fluent.
CFX vs. Fluent Results n.sharifi CFX 8 November 3, 2010 16:40
why can't i examine the results after iteration in fluent Mixsim 2.0? xiqiu FLUENT 0 September 11, 2009 04:21
why can't i examine the results after iteration in fluent Mixsim 2.0? xiqiu FLUENT 0 September 11, 2009 04:20
fluent output pressure of elements in xyz Fred FLUENT 3 July 16, 2005 03:51
data output from batch fluent run Wang FLUENT 4 March 11, 2005 11:01
