how to get the particle relative acceleration?
Like Tree1Likes
  • 1 Post By winnie
Old   May 7, 2003, 22:24
Default how to get the particle relative acceleration?
winnie
In fluent dpm, particle force balance can include the virtual mass force which is written as:
F=1/2*rho_l/rho_p*(du/dt-dup/dt)
This is also mentioned in fluent document. But in fluent, how can we get this force using udf since we can't access particle acceleration??
anyone has dealt with it??
Regards
winnie
Old   June 2, 2003, 03:48
Default Re: how to get the particle relative acceleration?
tuki72
I calculated this one as follows:
1)I know u_f and u_p ate certain point and time 2) Then I know these after delT 3) I use d(u_f2-u_f1)/delT=du_f/dt and same for particles 4) Then subtract these two to find VMS.
I made it automatic, so its easier for me.
How do you calculate SLF (Saffman Lift Force) in fluent ??
I know how to, but I am just wondering how do?
tuki72@hotmail.com
Old   June 2, 2003, 09:08
winnie
Hi, my friend
Thank you so much for your reply in the fluent online forum since this problem confused me a long time.
But I have tried this method, and the result is that when I include the virtual mass force, each dpm iteration will cost a long time which seems to me that this method is unsuitable because the time step is so small that the ultimate virtual mass force magnitude can be too large which made the particle have a great displacement during a time step. So I give it up. Now, since you have tried this method and it seems good to you, I will try once again, maybe I neglect something. Thank you.
As for the Safman lift force, since my case is the bubbly flow in which the bubble is about 1-5mm and safman lift force is important in low Reynold number case, I don't include saffman lift force in my case, instead, I include magnus force.
Thank you again for your help!!
Best regards
winnie
Old   June 2, 2003, 09:39
winnie
Hi, my friend
Now I have some question about the method you provide to me.
1. for continuous phase, namely the fluid, we can get the velocity at the current location and time C_U(c,t), C_V(c,t), C_W(c,t) and the velocity at the previous time step C_U_M1(c,t), C_V_M1(c,t), C_W_M1(c,t), but it seems that only in unsteady calculation the continuous phase is related to the time, but my case is the steady one, how can I get the fluid accelaration in steady calculation.
2. for particle, we can get particle velocity at current position and at entry to current cell, and fluent provide time step P_DT(p) and two time P_TIME(p) and P_TIME0(p), my question is that is P_DT(p) equal to (P_TIME(p) - P_TIME0(p)), if they are equal, does the velocity varience between particle velocity at current position P_VEL(p)[i] and particle velocity at entry to current cellP_VEL0(p)[i] happen during this time step? if they are not equal, which one should be chosen?
Sorry for so many questions. Thank you again for your help!
Best regards
winnie
Old   June 2, 2003, 10:17
tuki72
Lets try to answer:
1) for steady state fluid flow:du/dt=0, so in way you asked a stupid q when its converge, its down, no du/dt [please note that I understand in a SS case you are trying to calculate du/dt for the fluid flow 2) for a Unsteady state fluid flow u have du/dt, some times u may want:a) from a SS fluid flow, you swithc to US as u inject particles, in that case can:i) freez the fluid flow or ii) US fluid flowa as the particulate flow b) From the beginnning, u can have US fluid flow and/or u can inject particle as US case. In reality SS particulate flow is rare, however if u do such a simulation, du_p/dt=0 as well.
Now did I answer ur query?
Here are my questions:
1) At certain point and time, for a US case, u want to calculate VMF for all the points the particles are at the moment? So if u have 10,000 points (particles), what do u do? 2) U ignored SLF calculation, could you really prove (by calculating by the above procedure) that SLF is negligible (wrt to gravity force for example)?
I have more difficults questions, I have just started with the easiest ones
tuki72@hotmail.com
Old   June 2, 2003, 21:08
winnie
Hi...
I think there are some concepts we should share.
In discrete phase model, the continuous phase is described in Eulerian method and the particle is described in Lagranian method. These two methods give us different results: the former gives the parameter of the point in the field and the later gives the parameter of the particle during its trajectory, so when we calculate du_f/dt-du_p/dt , we should choose either Eulerian method or Lagranian method, but not both.
In Eulerian method, the accelaration Du/Dt is calculated as:
Du/Dt = du/dt + du/dx * u + du/dy * v + du/dz * w
In lagranian method, the ccelaration Du/Dt is calculated as:
Du/Dt = [u of particle at (t + ¡÷t) - u of particle at t] / ¡÷t
waiting for your opinions!
best regards
winnie
So, for steady problem, whether we use Eulerian method or lagranian method, the acceleration can't be equal to zero.
Old   June 2, 2003, 22:08
winnie
Hi, my friend
Now I use following expressions to calculate the acceleration:
for continuous phase:
lut=lux*lu+luy*lv+luz*lw;
lvt=lvx*lu+lvy*lv+lvz*lw;
lwt=lwx*lu+lwy*lv+lwz*lw;
in which lut means du_l/dt , lux means du_l/dx and so on...they can access from:
lu=C_U(c,t);
lv=C_V(c,t);
lw=C_W(c,t);
lux=C_U_G(c,t)[0];
luy=C_U_G(c,t)[1];
luz=C_U_G(c,t)[2];
lvx=C_V_G(c,t)[0];
lvy=C_V_G(c,t)[1];
lvz=C_V_G(c,t)[2];
lwx=C_W_G(c,t)[0];
lwy=C_W_G(c,t)[1];
lwz=C_W_G(c,t)[2];
and for particle:
but=(bu-bu0)/dt;
bvt=(bv-bv0)/dt;
bwt=(bw-bw0)/dt;
in which
bu=P_VEL(p)[0];
bv=P_VEL(p)[1];
bw=P_VEL(p)[2];
bu0=P_VEL0(p)[0];
bv0=P_VEL0(p)[1];
bw0=P_VEL0(p)[2];
dt=P_DT(p);
Although they are got using different method(the former: Eulerian method; the later: Lagranian method), the result of two method is equal to each other in steady problem.
When I use it in my case calculation, fluent can't go on when the first dpm iteration comes. So I think there must be something wrong that leads to some problems fluent can't deal with.
But what's the matter??
Please help me!
best regards
winnie
afzal zahiri23 likes this.
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
Problems involved heat transfer inside a particle and its thermal degradation zhangr STAR-CCM+ 2 August 25, 2011 06:59
Particle Tracking for ion Jun CFX 2 August 31, 2010 08:19
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Particle acceleration CFD_MAN FLUENT 3 November 28, 2002 06:17
