GRID TO GRID INTERPOLATION in FLUENT
Old   May 16, 2003, 02:49
Default GRID TO GRID INTERPOLATION in FLUENT
calogero
Hi everybody: did somebody already perform grid to grid interpolation in fluent? in fluent_UG section.3.14: http://www.psc.edu/general/software/...e105.htm#12579 it is said: **FLUENT can interpolate solution data FOR A GIVEN GEOMETRY from one grid to another, allowing you to compute a solution using one grid (e.g., hexahedral) and then change to another grid (e.g., hybrid) and continue the calculation using the first solution as a starting point.** what is the meaning of "for a given geometry"? is it the wall (or solid body) position in the grid?? cuz I have a moving airfoil(two in another case moving relatively one to the other)what I change from a grid to the next one is the position of this foil in the grid. is it ok to interpolate the previous grid data to be used as a starting point to the next grid? thanks for any help
Old   May 22, 2003, 09:05
Default Re: GRID TO GRID INTERPOLATION in FLUENT
Dennis
I have tried ,it is ok.
Old   May 23, 2003, 02:34
calogero
thanx Dennis! do you mean it is ok for my case? although I change the grid (by changing the solid body's position in it)! do you know in more details how this interpolation is performed by fluent? thanx
Old   June 4, 2003, 08:32
caloggero
Hi Dennis ! I tried interpolating data from one grid to another, but the spacial position of the body changes from the first to the second one, thus it gives me in the new grid (at the place where was initially the body in the previous mesh), data am afraid is wrong. but after doing the calculation for the second grid, I find something normal.what do you think about that? do you have any idea about how fluent performs this interpolation? thanx
momentum interpolation for collocated grid Hadian Main CFD Forum 4 December 25, 2009 07:25
Fluent, Grid Builing Issue Mark FLUENT 4 March 14, 2008 15:24
grid in FLUENT5.5and FLUENT 4.5 yueroo FLUENT 0 March 8, 2001 08:19
computational grid generation on fluent Terry FLUENT 3 February 13, 2001 10:33
How to do Grid Generation for the FLUENT? timea Main CFD Forum 2 April 7, 1999 09:03
