CAVITATION(similitude of two cases)
Old   August 2, 2003, 03:49
Default CAVITATION(similitude of two cases)
ROOZBEH
Hi all; I have had a problem with cavitation modeling at high speed(20m/s or 40m/s or 60m/s). My problem was the negative absolut pressure or a domain with pressure under vapor pressure in flow field.It is strongly wrong. Because suggestion of Mateus, I increased my velocity inlet from 0 to 20 by .5 increments and for each velocity I allowed Fluent to go 50 time steps.(each time step is 2e-5s)But at velocity 16m/s I again resieved a negative absolute pressure. Therefore I have decided to work with reynolds and cavitation number with low velocity and high Lch and vapor pressure as in Fluent tutorial. Is this a correct work. Please guide me for these problems
How to speed up the simulation of a large amount of similar steady state cases tss Main CFD Forum 4 November 5, 2010 14:36
CFD Validation Cases doug Main CFD Forum 4 January 11, 2010 19:28
Directory constructions of complex cases 7islands OpenFOAM 2 August 26, 2008 05:25
Coupled cases kevin FLUENT 1 July 24, 2004 01:50
Standard CFD test cases? Damon Qualski Main CFD Forum 1 April 10, 2003 14:10
