Help!! Velocity fluctuation in LES
Old   August 5, 2003, 05:20
Default Help!! Velocity fluctuation in LES
ada
Can anybody help me to find the velocity fluctuation in LES? I could find the average velocity, but I don't know how to display the instantaneous velocity or velocity fluctuation.Thanks for your help!!
Old   August 5, 2003, 05:40
Default Re: Help!! Velocity fluctuation in LES
Andrew Garrard
The way I used to do it when I was working with LES is to save data files for each time step. I believe an execuatable command can be set up to save the data file at the end of every time step using a %t command. If there is a more elegant way of doing it I would be interested in hearing about it.
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
Emergency:UDF for a time dependent parabolic velocity zumaqiong Fluent UDF and Scheme Programming 12 March 25, 2010 12:00
Frictional Velocity + LES Harry Main CFD Forum 3 July 31, 2005 11:24
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Velocity fluctuation. In let. Main CFD Forum 1 October 21, 2003 14:37
