help in fluent
Old   August 26, 2003, 04:50
Default help in fluent
xqz1997
I specify the boundary information :wall-container,wall-fiber1,wall-fiber2,wall-fiber3,wall-fiber4,and pressure-inlet.5;They are all changing in the fluent . wall-fiber1,wall-fiber1:015 wall-fiber2,wall-fiber2:014 wall-fbier3,wall-fiber3:013 wall-fiber4,wall-fiber4:012 pressure-inlet.5,pressure-inleet.5:001,pressure-inleet.5:007. why do they add so many walls?and how can I delete the surplus wall in fluent? please tell me the reason,Thank you very much.
Old   August 26, 2003, 05:35
Default Re: help in fluent
ap
I think FLUENT just splits your existing walls while reading the mesh you generated in GAMBIT.
Anyway, you don't have to delete anything to do your calculation.
Hi
ap
Old   August 26, 2003, 08:24
kim
If you defined two names of fluid in the gambit, fluent usually will split the boundary walls.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
