September 10, 2003, 05:38 |
AUTOCAD
Please advise how to export lines and surfaces from AutoCad to Gambit. It seems that AUTOCAD can only export solid (volume) in ACIS format. Thanks
September 10, 2003, 11:24 |
Re: AUTOCAD
Gambit can still see vertices and edges created in AutoCad and saved as an ACIS (*.sat) file provided they were there originally. You may have to fool around in Gambit to delete volumes, surfaces, etc.
Alternatively, you could convert the AutoCad file (is it *.dxf?) to an IGES file. You will have to find a translator, such as can be found in the professional version of some of the low end CAD packages - Generic CAD? VersiCAD?. You can find some stand-alone conversion programs on the Web to go from CAD to IGES format. I have tried a few with limited success. |
September 12, 2003, 04:49 |
Re: AUTOCAD
Thank you very much for your reply. I will try as per your suggestion. regards!
[Other] Import autocad into Design modeller | lcea | ANSYS Meshing & Geometry | 1 | December 1, 2010 13:15 |
Import autocad into Design modeller | lcea | CFX | 0 | November 30, 2010 04:13 |
AutoCAD file import enGrid / Netgen | deniggo | OpenFOAM | 1 | August 4, 2010 09:38 |
Civil Engineers and AutoCAD | H | Main CFD Forum | 0 | February 26, 2009 18:07 |
Meshing AutoCAD geometries using ICEM | Yuqing | CFX | 2 | November 16, 2006 20:08 |
