error in using UDF for specifying drag coefficient |
September 17, 2003, 05:53 |
i am getting an error: Error: Set_Property: null user-defined-function name Error Object: ()
while setting the UDF(interpreted) for specifying the drag coefficient in Eulerian multiphase model using the macro DEFINE_EXCHANGE_PROPERTY. |
September 17, 2003, 07:24 |
Re: error in using UDF for specifying drag coeffic
Have you defined a name (the first argument of the macro) for your UDF?
DEFINE_EXCHANGE_PROPERTY (name, c, mixture_thread, second_column_phase_index, first_column_phase_index) Good luck, Ale |
September 17, 2003, 08:34 |
I had the same error using interpreted UDF. I "solved" it doing this way:
- Start FLUENT and load the mesh file, then the UDF (Define -> User Defined -> Functions -> Interpreted). - Set up the case. When you choose your drag factor, you'll obtain the error. Ignore it. - Save the case file and exit FLUENT. - Open FLUENT again and load the case file. FLUENT automatically compiles the UDF. - Set your drag factor again. Now you shouldn't see the error message. Hi ap |
September 18, 2003, 03:48 |
Thank you for your reply. I have defined a name for my UDF as the first argument to the DEFINE macro.
September 18, 2003, 03:50 |
Hi ap, Thnak you for your reply. It indeed worked thanks a lot.
Drag Coefficient for Ellipse Form (2D) | Ketut Utama | Main CFD Forum | 8 | December 11, 2014 11:03 |
Problem with UDF (Drag model) | understate | FLUENT | 0 | January 4, 2011 05:01 |
Solidification drag coefficient | atulverma | FLOW-3D | 1 | May 14, 2009 09:24 |
drag coefficient & drag force | abhishek.mnit | FLUENT | 0 | April 29, 2009 23:48 |
Drag coefficient for parcels in dieselFoam | sebastian_vogl | OpenFOAM Running, Solving & CFD | 5 | December 31, 2008 12:19 |
