Turbulent Viscosity Ratio
Old   November 3, 2003, 07:53
Default Turbulent Viscosity Ratio
deven
We are trying to simulate a subsonic (Mach no: 0.6) turbulent internal flow in an S shaped diffusing duct. We are specifying the pressure inlet turbulence boundary conditions using turbulence intensity (5%) and hydraulic diameter (0.4 meter). FLUENT calculates turbulent viscosity ratio of around 11000 at the inlet from our turbulence boundary conditions. Is this a reasonable value? We were expecting this ratio in the range of 10 to 100.
Any direct guidance on this OR any sources for finding out more will be helpful.
Thanks, deven
Old   November 3, 2003, 11:18
Default Re: Turbulent Viscosity Ratio
Davide
Yes I agree with you! It's pretty high! For a value of 5% of turbulence ratio, it should be about 50 in my opinion.
Turbulent viscosity ratio Balaji FLUENT 5 May 27, 2014 03:47
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 11:04
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
On limiting to turbulent viscosity ratio! varghese FLUENT 2 November 15, 2003 08:56
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
