Outflow boundary condition in FLUENT
Old   November 12, 2003, 03:53
Default Outflow boundary condition in FLUENT
Sri
Hi.....
I am new to FLUENT. I am unable to understand what OTUFLOW boundary condition means in FLUENT 5/6 solver. The only thing I could get is that it can be used in case of pipes where flow is being divided and u have the convenience of specifying the mass flow ratio into each branch. For my case, I have a single pipe and so it would be 1.
But what are the conditions it uses, when we specify OTUFLOW as the boundary condition.
Does it assume fully developed flow condition at that end?
Old   November 12, 2003, 11:25
Default Re: Outflow boundary condition in FLUENT
ap
See the manual here:
http://p2chpd-cluster.univ-lyon1.fr/...ug/node201.htm
Hi
ap
Old   November 15, 2003, 19:58
Sri
Hi ap,
Thank you for the information. But it still remains doubtful about what information it extrapolates from the interior. Does it mean that it takes the boundary condition to be that existing just prior to the end of our geometry??
I also came across another posting which said that outflow boundary conditions typically assume fully developed flow type conditions. This confused me. But I think I am getting a feel of it now.
Thanx for the help once again
Old   November 18, 2003, 20:53
Alamgir
outflow bc is needed to be set to initialize how much fluid will be flowed out of the system/geometry. and it is assumed to be fully developed.
Alamgir
Old   November 22, 2003, 20:56
Default some more on: Outflow boundary condition in FLUENT
Sri
can we have two mass flow inlet boundary conditions for a sinlge outflow......?? I guess it shouldnt be a problem. Thax to one and all for their response.
Sri
Old   December 5, 2003, 04:42
Default Re: some more on: Outflow boundary condition in FL
ap
Yes. You can define as many inlet as you want.
Hi
ap
outflow boundary condition ravi_adepu FLUENT 11 January 19, 2018 07:13
Handling boundary condition in Fluent sak FLUENT 6 March 25, 2013 15:21
change a certain input boundary condition to a different material in FLUENT 6 haze_1986 FLUENT 0 July 4, 2011 06:15
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
how to apply cauchy type boundary condition in fluent aksrun FLUENT 0 January 30, 2010 08:07
