unphysical temp fluid/solid region
Old   December 11, 2003, 03:42
Default unphysical temp fluid/solid region
jonas
When modelling heat transfer between a solid and a fluid region unphysical temperatures appeared at the solid/fluid interface. I solved this by using the following (obtained from fluentusers solution 745):
rpsetvar 'temperature/secondary-gradient? #f
My question is what the above command really does?? It's not equivialent to solving the energy equation by first order upwind, or is it? thanks!
[snappyHexMesh] Multi region meshing & recovering the original patch names fluidpath OpenFOAM Meshing & Mesh Conversion 4 May 19, 2013 19:13
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
