three phase problem in packed bed
Old   December 18, 2003, 18:05
Default three phase problem in packed bed
Janice
I am simulating three-phase problem - air, water cocurrent flow through a bed of solid catalyst. First step is looking at the flow behavior like pressure drop, gas void fraction, etc. Should i use two phase simulation with porous zone or true three phase simulation? What kind of model is approprate, Mixture or Eulerian?
Old   December 18, 2003, 22:32
Default Re: three phase problem in packed bed
ap
I think you should simulate your system using a three phase simulation, specifing the granular phase with the Packed Bed option enabled (FLUENT 6.1).
I'd suggest the Eulerian model.
Hi
ap
Old   December 21, 2003, 04:38
chandra
i see, i used fluent 5.2, i dont know if new fluent can simulate 3 phase,:P
Old   December 21, 2003, 07:59
ap
Yes. Fluent 6.0 and 6.1 implement the Eulerian-Eulerian multiphase model, which allows you to model a general number of phases, including granular ones, which can be described with the kinetic theory approach.
Anyway the option for packed bed is only present in FLUENT 6.1.
Hi
ap
Old   December 21, 2003, 18:35
chandra
thank you, do you know the journal to guide for modeling heat transfer in paralel flow pipe?
Old   January 5, 2004, 12:56
Janice
Thank you, AP. Have you tried this problem before? Did you experience any convergence problem with 3 phase Eulerian model? What do you think if i use two phase model like VOF with the porous media option on?
Old   August 12, 2010, 03:49
Kevin.J.B.Cheung
jambo is on a distinguished road
I am a little late to reply. But I think you should use two phases and eulerian to do with your problem.
jambo is offline   Reply With Quote
Old   October 5, 2010, 08:48
subha_meter's Avatar
Subhasish Mitra
subha_meter is on a distinguished road
I've tried to model a Trickle Bed reactor by both options 1) Three phase eulerian 2) 2 phase eulerian with porous media. Both simulations had convergence problem.
Problem for Gas & liquid phase is how to define the bubble dia considering gas is continuous phase.
For the 3 phase case, I patched solid vol fraction i.e. (1 - bed voidage ) in the solution domain, but to my surprise, solid volume fraction keeps on changing and eventually get replaced by the liquid & gas which is not correct.
Anybody has any clue?
Response will be appreciated.
subha_meter is offline   Reply With Quote
Old   October 14, 2010, 08:46
Kevin.J.B.Cheung
Try to set the solid to be packed bed
Old   April 2, 2015, 02:04
Default CFD in Trickle Bed reactor
Rahul omar
omar.rahul is on a distinguished road
email- omar.rahul51@gmail.com
omar.rahul is offline   Reply With Quote
Old   December 9, 2015, 03:42
Smile
  #11
Liam
Many is on a distinguished road
What about fixing the velocities of your solid particles in the whole domain to 0?
Also I have read that two phase flow with porous media does not work well in FLUENT, unless you set relative permeabilities via UDF.
The question is that I have tried to model a fixed bed inside a tube using:
1 Three phase flow
2 Single phase flow (with species transport describing my mixture) and porous media for the fixed bed of solid particles using Blake-Kozeny equations for alpha and C1 (based on solid concentration and diameter of solid particles), but I have found that quite different values (for pressure drop for instance) are provided by each model.
Am I missing something or should this two models lead to similar results?
Many is offline   Reply With Quote
Fixed Bed Gasifier, Species Transport Problem therandomestname FLUENT 12 January 4, 2019 07:08
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) balu@gold6 FLUENT 4 July 26, 2012 10:37
gas-liquid upflow and downflow in packed bed ,the Ergun pressure drop is same? W7032654 FLUENT 0 March 11, 2011 21:26
Packed bed using euler-euler akm FLUENT 0 May 28, 2010 05:40
help needed packed bed option gandhi FLUENT 0 October 11, 2006 01:40
