Mass balance problem!
Old   December 19, 2003, 13:07
Default Mass balance problem!
JADG
Hello!!
I have problem with the mass balance in a pipe with one inlet and two outlets. I am using velocity inlet and Pressure outlet as B.C. But the mass balance doesn't mach, there is a difference of 20% between the mass flow rate at the inlet and the outlets. Any ideas how can I close the mass balance?
Thanks in advance
JADG
Old   December 20, 2003, 06:13
Default Re: Mass balance problem!
ap
You could try reducing the accepted residuals for convergence of the continuity equation.
Hi
ap
Old   December 21, 2003, 06:41
Venkatesh
I hope you must be using the segregated solver. Just plot the contours of Mass Balance and you can find where the mass balance residuals are high. Check the quality of grid at that location. If you feel the quality is OK then reduce the convergence limit.
Old   December 21, 2003, 14:33
JADG
Thank you guys I will reduce the residual limits.
JADG
Old   December 27, 2003, 10:40
Sijal Ahmed
set the target mass flow rate by the mass-flow-rate-settings text command
bye
DPM mass problem Henrik Ström FLUENT 9 May 20, 2016 11:00
mass convergency problem c120613 CFX 1 May 25, 2010 07:20
Multiphase mass balance GZD Siemens 0 August 6, 2008 13:37
The mass balance in restriction of FAS implement Tiger Main CFD Forum 1 September 15, 2006 11:13
mass injection in a 2D axi-symmetric problem hyun Main CFD Forum 1 April 26, 2006 00:25
