to find drag coefficient of an ogival body
Old   January 26, 2004, 09:39
Default to find drag coefficient of an ogival body
ace
Hi ! I want to find the drag coeff of an ogival shape. I have made the grid in fluent with press inlet boundary condition far ahead of the ogival body and press outlet at the end of 2D ogive. The mach # is 0.6 in standard atmosphere, the solution doesn't converge after a lot of iterations. i have changed the press inlet condition to press far field but the problem remains there. the shape of the domain is just like the alphabet 'D' with ogival shape attached to outlet boundary from behind.
If I give supersonic M# the solution is fine, I see perhaps press outlet b.c is creating problem....what pressure should I give at press outlet as i see that this is the only b.c condition for outlet available for compressible flows
Old   January 26, 2004, 22:04
Default To estimate drag coefficient of an ogival body
ace
Hi! its urgent...can someone help
Old   January 27, 2004, 10:14
Default Re: To estimate drag coefficient of an ogival body
ace
Hi All
Any ideas if std press is given at press inlet or press far field ahead of the body , what press to give at press outlet attached to the rear of the body for compressible flows.......
Drag Coefficient for Ellipse Form (2D) Ketut Utama Main CFD Forum 8 December 11, 2014 11:03
Solidification drag coefficient atulverma FLOW-3D 1 May 14, 2009 09:24
drag coefficient & drag force abhishek.mnit FLUENT 0 April 29, 2009 23:48
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
How to find the drag coefficient for internal flow Fredrick Main CFD Forum 1 February 15, 2005 10:16
