Boundary between two adjacent fluid faces!
Old   February 11, 2004, 04:51
Default Boundary between two adjacent fluid faces!
A8anato_psofimi
Hi, This is a very simple question, but I am new to CFD and FLuent. I have made a 2D towing tank in Gambit, and I am setting the fluid regions, and the boundaries. I have multiple adjacent faces, some structured and some unstructured, and they all have the same fluid. In the actual model I want it to be seen as one piece. Do I need to set a boundary for the edges between the two faces, or if I do not set anything it will assume it is continuous if the two faces are both set be fluid regions? Thanks
Old   February 11, 2004, 05:33
Default Re: Boundary between two adjacent fluid faces!
Tom
You only need one edge to share both faces for the fuid to move between the two. Otherwise Gambit will create a wall. Use the connect edges command.
Old   February 11, 2004, 05:43
A8anato_psofimi
It is one edge between each face. I was just wondering if I need to set the edge as some boundary, or just leave it. From what you say, it seems to me gambit sees it as continuous, which is what I want.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
about compresive phase James CFX 10 September 12, 2006 03:16
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
