help on AMG soler error
Old   February 11, 2004, 12:50
Default help on AMG soler error
zwdi
Hello everyone,
When I runing POWER LAW or Quick scheme in my model, fluent give me the error: diverge in AMG solver: X-Momentum. I could not figure out what cause this problem. Does anybody give me a help on this error? For my case, first order and second order scheme works well. Because my grid is T-Grid, so I think power law scheme is better for my simulation. Any helps are appreciated. Thanks.
Zwdi
Old   February 11, 2004, 13:18
Default Re: help on AMG soler error
wang
Check you boundary conditions to see if it is well defined.
Old   February 11, 2004, 13:42
zwdi
Thanks, Wang. I used the same boundary conditions as upwind scheme. Do you mean if I change discrete scheme(upwind, power law, quick), I should change boundary conditions? Add one point: I use RSM turbulent model.
Zwdi
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
