February 14, 2004, 02:05 |
EVAPORATION??!!!
Hi. This is my last hope here. Do any body knows relations are equations for evaporation from liquid surface because of side-wall heat flux on the container(cylindrical) walls. the liquid and the vapor(gas) above the liquid are both of same fluid : HYDROGEN that is it single fluid, two-phase prob. with evap.
awaitng for a least response prasanth |
February 27, 2004, 03:29 |
Re: EVAPORATION??!!!
Do you want to know the mass transfer rate equation?. FJ |
February 27, 2004, 03:42 |
yeah for that single fluid, evaporation of liquid into its vapor. saturation temp dependent on vapor pressure. thanks and regards prasanth
March 10, 2004, 02:00 |
Generally mass transfer rate due to evaporation is D*M/R*(Pv/Tg - Pv_sat/Tb)/delta. Diffusion coeff(m2/s) M:Molecular Weight of vapor(kg/mol) R:Gas constant(J/kmol) Pv:Partial pressure of vapor at a wall adjacent cell. Tg:Temperature at a wall adjacent cell. Pv_sat:Stauration pressure of vapor(constant or a function of temperature) Tb:Temperature at a wall delta:cell hight. Thank you -- FJ |
Evaporation model in ansys Fluent 12.1 | oldisbest | Fluent UDF and Scheme Programming | 12 | March 26, 2020 09:11 |
Evaporation due to Heat Transport using InterFoam (Correct Implementation?) | ovie | OpenFOAM | 14 | August 3, 2019 07:00 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 20:47 |
CFX Liquid Evaporation Model | Jinx | CFX | 3 | January 28, 2010 16:31 |
Defining Evaporation - A How To Guide. | Owen | FLUENT | 1 | July 25, 2005 09:56 |
