I'm modelling a car mockup in a wind tunnel, and I'm defining a symmetry plane along the longitudinal axis of both. I'm interested in the Cd an Cl of the car buy I've a doubt: In the turbulence specification method (in hidraulic diameter) and in the area of reference values, I've to introduce the total front surface of the car mockup or only the half value of this surface due to the symmetry used? Thanks a lot.
Hi, Are you specifying the inlet or outlet condition of the wind tunnel? if it's so, there is no need to consider the hydraulic diameter of the car mockup.
Hi. Thanks for your response. I'm specifying the inlet as "velocity inlet" and the outlet as "outflow". In the "velocity intel" dialog box I'm specifiying the turbulence by the turbulence intensity of the wind tunnel and the hydraulic diameter of the car, introducing the half of frontal surface of this one. I've constated that this value isn't really relevant for the drag coefficient (the variable that I'm interested in), the fundamental value is the area used for adimensionalize the force and introduced in the "Reference values..." dialog box, and I don't know what I've to introduce: the total frontal surface of the car or only the half of this surface. Thanks.
hi, if I understand you correctly, you should use the hydraulik diameter of the wind tunnel inlet for the turbulence specification at the inlet other than the one of the car. To calculate the normalized forces, you need to input the half surface area. The symmetry condition only provide kind of boundary condition. You are not supposed to get the forces acting on the whole car by using the symmetry boundary. Hope it helps.
Thanks a lot, Jun.
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
Forces in Symmetry | Matt | CFX | 2 | February 25, 2009 05:41 |
Symmetry plane error in solver | Santiago Orrego. | CFX | 6 | January 31, 2007 07:09 |
radiation and symmetry | Mark | FLUENT | 2 | November 4, 2004 13:50 |
