March 18, 2004, 12:05 |
pressure field problem.
Hallo,
I'm working on problem of natural convection.(a tank with water inside,heated trom bottom) If I use bussinesq model of density everything is ok. The problem begins when I use polynominal ,piecewise-linear, or piecewise-polynominal model. The the static pressure field should grow with -Z direction , but in the middle of tank I have divergence. The problem exists even with high Ra.numbers. For every send message thanks a lot. Michal |
March 18, 2004, 14:45 |
Re: pressure field problem.
I don't have much experience in natural convection modelling, but what is your pressure differencing scheme? I believe there is an option that is better for problems with substantial body-forces than the default.
Modifying pressure field in CFX | akultane | CFX | 2 | January 13, 2010 14:42 |
Pressure correction problem | richard_larson | OpenFOAM Running, Solving & CFD | 8 | October 30, 2008 08:48 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Problem with the pressure field using interFoam | zoune | OpenFOAM Running, Solving & CFD | 20 | February 4, 2008 18:42 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
