cas file to msh file
Old   March 25, 2004, 04:54
Default cas file to msh file
gg
I want to extract only mesh+bc from fluent cas file.
Any hints?
Old   March 26, 2004, 04:25
Default Re: cas file to msh file
zxaar
at least mesh you can get from cas by using gambit , in import-mesh option, and then write it again.
Old   March 26, 2004, 07:23
Jim Clancy
what about the multigrid meshes created in Fluent?can we import it again to gambit?
Old   March 30, 2004, 09:32
zxaar
I may be wrong but this is what I belive: The multigrid methods are based on coarsening of meshes and solving pdes on the coarse grids thus generated, then transfer of the solution to fine meshed, known as restriction and prolongation. The reason is when we use solvers as Gauss Seidel, as the mesh sizes decreases the difficulty in convergence increases, error behaves something like proportional to 1/h , where h is grid size. So the basic idea of multigrid method is to solve for large h and transfer the solution to finer meshes. On structured grids this can be obtained by simply not considering alternate node, and on unstructured meshes , the data structure that stores the mesh is Graph, so this can be obtained by simply collapsing some edges in some direction. So considering this, the multi grids are generated at the data structured level and the memory occupied by them is released as soon as the solver run finishes. This all suggests that the multigrids are not stored in case files (since dynamic allocation takes place and allocation can vary with multigrid parameters). So in my opinion we can not get the multigrid meshes so generated in case file.
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
