compiling UDFs
Old   April 20, 2004, 09:20
Default compiling UDFs
Shanice
Hi everyone
I´ve tried to compile my udf using Microsoft Visual C++ Toolkit 2003 (free download version) and typing "nmake" but "nmake" is unknown to this compiler. Do you know why or which compiler I should use to make it work...?
Thank you very much!
Old   April 20, 2004, 14:22
Default Re: compiling UDFs
Rob Hart
I don't have any experience with this toolkit, but try the following.
Does it contain a file called nmake.exe (use find files to look for it), and is the location of this file mentioned in the PATH variable? (open a command prompt and type echo %PATH%)
Rob
Old   April 20, 2004, 23:57
lingo
Shanice:
I thingk that You should't compile your udf in visual c++,You should compile it in fluent according to the turorial.
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) Ali.beh Fluent UDF and Scheme Programming 3 August 27, 2018 04:22
Compiling UDFs under Windows XP Hannah FLUENT 3 February 13, 2005 08:16
Compiling and Running UDFs on an IBM Power3 S. Hollman FLUENT 0 January 6, 2005 11:23
Compiling UDF's in Fluent 6.0 ramesh FLUENT 2 June 11, 2004 17:34
compiling UDFs in NT Fabio FLUENT 1 June 26, 2000 11:17
