Hello everybody!!! I have a problem with the continuity's residual convergence.I use the k-epsilon realizable model and I have about 17000 cells. The calculation converges very well at the beginning of the calculation but just before the half of the calculation, the continuity's residual gets instable and doesn't converge. For information, the under-relaxation factor for pressure is 0.3 and 0.7 for the momentum.I have 200 time steps of 5e-4 seconds and 1000 iterations per time step. If anybody has an idea, he will be welcome. Thanks!!
I think you should try to reduce the under releaxation factor as per the manual.
0.2 for the pressure 0.5 for the momentum,k and epsilon?
yeah may be
You should keep your pressure and momentum urf's equal to 1. So if pressure = 0.4 momentum = 0.6.
This was discussed in this forum sometime ago but I can't remember under what heading, sorry. Eric |
i think the sum should be 1.0 only for the SIMPLEC method as I understand in the FLUENT guide
Problem with residuals, especially continuity | Ozgur_ | FLUENT | 2 | December 3, 2013 05:48 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
