how to increase time step size?
Old   May 12, 2004, 13:28
Default how to increase time step size?
co2
hi all,
I am solving a natural convection unsteady problem. I am getting good convergence in 20 iterations per time step for a step size of 2 sec. --- so I decide to move to 3 sec time step size -- That results in a problem -- continuity residual does not seem to go down. it hovers around 1.6e-4 yes, i have nice stringent convergence criteria for an accurate solution. Can you tell me how i can run my simulation at 3 sec time step size? what urfs do i need to bring down ? both my presure and vel urfs are at 0.1 already.
thanks, co2
Old   May 13, 2004, 03:55
Default Re: how to increase time step size?
Tom
Are you using the PISO scheme for pv coupling? If so you can set your urf much higher. How good is your mesh?
Old   May 13, 2004, 04:03
ap
I'd try to increase the underrelaxation factor for pressure, usually this leads to a faster convergence.
If residuals stay high, keep the time step you're using.
Hi
ap
Old   May 13, 2004, 12:08
co2
my mesh is good with about 27000 cells for a 2D axi problem. I am seeing good results.
I am using PISO for pv coupling -- but trying to increase p and v urfs does not seem to help. Thus I guess there is no possibility of increasing the time step size
Old   May 14, 2004, 06:01
Venu gopal
Haai, This is venugopal from IIT MADRAS. Regarding to your problem, for natural convection always you have to go for less time step size, in the sense below one. If you are increasing the time step above one or more, the discretization error increases, and some times you will face the problem to get converged solution as what you told. So, you go for less convergence, if you are going below 1 sec, you will get good results. Increasing time step means, increasing erros. Bye Venu Gopal
Old   May 14, 2004, 11:00
co2
thanks everyone for your reply. I think my mesh is good. The only skewness is because of the meshing of solid zones in my model -- I have to model the thin steel walls of my tank as I have to put heat source terms in them to account for external sun radiation.
91 % cells have equiangle skewness less than 0.1
Old   May 17, 2004, 07:25
kethireddy
Hi This is kethireddy from RWTH-Aachen.Germany. U reduce the concergence criteria for the equation u solving.If u want u can reduce the no of time steps in one second.(in the iterate menu for unsteady state calculations) ........ kethireddy
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Time step, Number of time step, Maxximum Iterations per time step sandisk FLUENT 0 July 18, 2011 02:57
Time Step Size Issue Mustafa Ayad FLUENT 1 November 17, 2010 05:33
Time step size Aline Siemens 1 August 20, 2004 11:08
