May 14, 2004, 12:12 |
cell seperation - error
when i try to mark some cells in the domain and then seperate them, i get the following error.
I try adapt --> region --> and then select my quad, circle etc.. I tried both of them. But i get the same error. Do you know the solution to this problem? Error: Separate_Cell_Thread: hanging nodes Error Object: () |
May 17, 2004, 09:13 |
Re: cell seperation - error
hi,
you can not separate the cells which have been refined by hanging node refinement. You should do the separation before the refinement step. |
May 17, 2004, 11:17 |
i see, thanks ozgur
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
