unexpected temperature
Old   May 17, 2004, 07:08
Default unexpected temperature
kethireddy
Hi all, I have a film (fully developed) for which i have already solved for underlying hydrodynamics.It is 2 phase flow( air-primary phase and fluid secondary phase). Now i want to solve energy equation.The maximum and minimum temperatures of wall are 450 and 300 K.I am using vof model And it i am calculating for steady flow. After few iterations I found stange value of temperatutes more than maximun temperature. If any one have the idea abt this unexpected temperatures. .... kethireddy
Old   May 17, 2004, 11:18
Default Re: unexpected temperature
Karthick Srinivasan
Hello Kethireddy
Please try to limit the temperature to 450 and 300 K by going to Solve->Limits, fix the max and min temp.
Else you can adjust the Energy values of the Underrelaxation factors in solve-> controls
Tell me if it helps,
Regards Karthick
Old   May 17, 2004, 12:02
kethireddy
Hi thanks for reply.I am interested in seeing temperatuture distibution.i dont want to force temperature to be changed.Then it will be diffficult to predict temperature distribution. I have infact played with under relaxaton factors.No use. any way thanks for email....kethireddy
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 05:56
Unexpected large decrease in Total temperature across the shock using sonicFoam JLight OpenFOAM 0 December 16, 2010 11:46
Unexpected large decrease in Total temperature across the shock using sonicFoam JLight OpenFOAM Running, Solving & CFD 0 December 15, 2010 05:47
