a problem in calculating pressure drop in Fluent? |
May 17, 2004, 22:46 |
May I ask you a question about how to calculate pressure drop in a long tube(acutually there is a big reservior in the middle).
I got some converged results and evaluated pressure drop(P_inlet - P_outlet). When I calculated each of inlet and outlet pressures, these results are like: Area-Weighted Average Static Pressure (pascal) -------------------------------- -------------------- outlet_pressure 0 Area-Weighted Average Static Pressure (pascal) -------------------------------- -------------------- inlet_velocity 386.72406 I think the net prssure(or pressure drop) is ~387 pascal. However, when I cosidered both of inlet and outlet pressures, the result(net or pressure drop) is different as before. Area-Weighted Average Static Pressure (pascal) -------------------------------- -------------------- inlet_velocity 386.72406 outlet_pressure 0 Net 193.36203 Net pressure=193. Why do these happen? Or net pressure and prssure drop are different? How can I calculate pressure drop from a point 1 to a point 2 in Fluent? Thanks for your answer in advance. |
May 18, 2004, 03:40 |
Re: a problem in calculating pressure drop in Flue
the "Net pressure" is just an average (again area-weighted) from all surfaces you have selected.
Bye George |
fluent convergence problem | josip76 | FLUENT | 0 | May 26, 2011 20:08 |
Pressure drop in a heat exchanger | Diana | FLUENT | 5 | December 13, 2007 09:33 |
How to give pressure inlet in Fluent | Vijayaragavan | FLUENT | 2 | December 13, 2007 03:21 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
