Eulerian Model HELP!!!
Old   June 24, 2004, 13:24
Default Eulerian Model HELP!!!
Nicholas Wood
Hey, I've been trying top model granular phase flow and I cannot get the equations to converge. I keep getting unstable residuals that oscillate. I've tried calculating intial solutions by turning off the volume fraction calculator. Initial conditions are calculated well, but once I turn on the volume fraction calcualtor I get oscillations and instability again.
PLEASE HELP
Old   June 28, 2004, 08:16
Default Re: Eulerian Model HELP!!!
ap
What kind of system do you want to simulate? What equations do not converge?
As general suggestions:
1) Use an hexaedral mesh, if possible.
2) Use the second order upwind or the QUICK discretization scheme for the convective term of transport equations.
3) Set the under-relaxation factors as follows:
Pressure 0.6
Momentum 0.4
Turbulence (both k and eps) 0.8
Leave the other values unchanged.
4) If you do an unsteady calculation, try to reduce the size of the time step.
Hi
ap
Old   July 5, 2004, 13:48
Nicholas Wood
Thank you, I will try those methods. I'm having especial difficulty in converging the contiuum and air velocity equations. I also have a lot of turbulent viscosities limited. I've heard this can be caused by an unstable problem.
Old   July 5, 2004, 14:49
ap
Turbulent viscosity limitation usually is due to a too coarse grid or to bad boundary conditions for turbulence variables.
Hi
ap
Old   July 5, 2004, 16:47
Nicholas Wood
The basic shape Im working with is a recatngular box with air blowing in one end and out the other. Along hte bottom of the box is another box where there is a bed of 'granular phase'.
It reflects two 'zones' representing the air and the granular phase(the granular phase on the bottom). I have a velocity inlet on one end and a pressure outlet on the other and walls every where else. I've tried many different mesh sizes with the same result: very unstable solutions with oscillation, especially in velocities and continuity equation. Thanks for your help.
Old   July 6, 2004, 15:45
ap
With the granular model of FLUENT I always have the turbulent viscosity limitation.
For convergence, what kind of drag factor are you using? I obtained good results using Syamlal and O'Brien formulation both for the drag factor and the viscosity of the granular phase.
Hi
ap
question about eulerian model for packed bed rone FLUENT 2 July 19, 2007 20:58
Mass and het transfer using eulerian model Pablo FLUENT 0 February 16, 2007 08:36
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 06:17
Strain Rate in eulerian model galeazzo FLUENT 0 January 25, 2005 07:52
