hi all,
i am getting this error message "pressure-outlet zone 5 has tow adjacent cell zones". can anyone help me with this problem. I am trying to create a room with a window. lemme know if the following procedure is correct. the 4 walls of the room are defined "wall" the opening in the wall is defined "pressure outlet" the outside envirnoment is defined as follows, the veocity inlet definition is for the wind. and the other two sides of the envirnoment are pressure outlet. is this correct thanks Ashish |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
