July 10, 2004, 09:57 |
bulk temperature
hi all how do i report bulk temperature from Fluent? please guide me best regard avesta
July 10, 2004, 17:48 |
Re: bulk temperature
Check area or volume averaged temperature where you're interested in bulk temperature.
thanks AJ |
July 11, 2004, 02:09 |
hi dear thank you but bulk temperature is difined as below: T_bulk=integral(UTdA)/integral(UdA) please guide me best regard Avesta
July 11, 2004, 11:59 |
As per the definition use custom field calculation to calculate the bulk temoperature for area/volume....
have fun!!! |
July 12, 2004, 01:56 |
hi AJ thank you i should define a function as U*T in custom fieldfunction ,then calculate surface integral (integral(u*T*dA) ) ,then integral(u*dA)and then devide them. ok is it correct? because i want to Nusselt number as below definition: Nu=(1/T_bulk)*dT/dr T is non dimentional temperature. IN A TUBE. please guide me. best regard Avesta
plot bulk temperature of fluid | mohammadkm | FLUENT | 4 | December 13, 2011 15:37 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 05:56 |
Bulk mean fluid temperature in internal flow | mssound | FLUENT | 0 | May 13, 2010 15:56 |
UDF or any approach for Bulk Temperature calculation | vemps | FLUENT | 0 | May 1, 2009 01:09 |
Bulk temperature for HTC extimation | Italy | CFX | 4 | July 12, 2007 00:05 |
