I am modeling the heat flow in a concrete floor heated with imbedded hot water pipes. For the top surface boundary condition I am using the mixed thermal conditions, where I can input the external emissivity and temperature for the radiative heat transfer. I can't find any place (such as "define materials") to input the emissivity of the concrete surface though. Even if I select radiation under "define models" I can't find any place to provide the surface emissivity. How does FLUENT calculate this? Does it assume an emissivity of the boundary of 1? Thanks for any information you can provide.
What Radiation model are you using?
I am not using a radiation model. I am just using the energy model but, I can still use a mixed boundary condition that incorporates both convection and radiation. It is the radiation part that I don't know how FLUENT calculates.
Dear ereiss ,you should take a global convection coeficient which includes conv+radiation
h=24.1*e-4*epsilon*pow(T,1.61) epsilon :emissivity ,T temperature and you write a UDF for this...... |
#5 | |
n7310889
Rep Power: 13 ![]() |
Could you please write the equation a bit clearly? And is it possible for you to give a reference for that, so that I can make some study. Another request is, I am modeling a conjugate heat transfer problem (liquid coolant flow through a tube), in which I have to give three boundary conditions on the outer surface of the tube: (non-uniform) functional heat flux as heat input, radiation loss and convection loss. But I don't understand how can I ensure all of these 3 at a time ![]() Could you please suggest me? I'll be happy if you may text me in my email. Regards n7310889 (murad99me@yahoo.com) |
Internal Emissivity boundary condition | Piastun | FLUENT | 1 | November 28, 2011 10:17 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
Temperature-dependent emissivity for DOM boundary condition | navier | OpenFOAM | 3 | September 30, 2009 18:48 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
Slip boundary condition what is inside | normunds | OpenFOAM Running, Solving & CFD | 2 | June 4, 2007 06:45 |
