modelling flow through a hole
Old   August 20, 2004, 15:50
Default modelling flow through a hole
Andrew
I have a hexagon tube with a heated plate in the middle of the tube with a single hole in the center of the plate. I have laminar flow, and have set the boundary conditions such that the inflow is 100k, and the plate is 400k. I am trying to determine how much heat the fluid(air) picks up as it flows through the hole at various laminar velocities. My problem is that the tube and exit region/temperature(pressure outlet) are affecting the temperature of the fluid after the plate. Is there any way to correct this? I don't want the walls after the plate to play any role in the temperature of the fluid. I am ultimately trying to get the convective coefficient for the frontside of the plate. I am determining the temperature by doing an average area weighted report on an exit plane.
Thanks
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
VOF modelling open channel river flow Matthew Roberts FLUENT 6 July 31, 2009 12:52
modelling blood flow in arteries with starcd sara Siemens 5 April 10, 2007 09:17
Basic Multiphase Flow Modelling krishna Main CFD Forum 2 August 27, 2004 08:40
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
