I need to model a round cylindrical heating element (volume) with thin fins attached perpendicular to the cylinder axis. The fins obviously need to be "connected" to the heating element, but I do not want to model them as volumes for meshing reasons. Basically, this involves two questions: 1) Is it possible (if so, how) to connect/join/merge perpendicular faces such as my heater cylinder face and the thin fin? 2)Is there a way to connect a face/wall to a volume and have the face/wall be in thermal contact with the volume? Thanks for any response.
Just create the walls in GAMBIT and assign them a name in the boundaries panel. In FLUENT, you will be able to specify a thickness for use in computations and a material. You will need to enable shell conduction for these walls.
[Gmsh] gmshToFoam unhandled element | flowris | OpenFOAM Meshing & Mesh Conversion | 4 | February 20, 2023 17:50 |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
autoPatch error, mesh quality related...? | Alexvader | OpenFOAM | 0 | October 6, 2011 17:57 |
heat transfer - heating element to air in FloWorks | Duncan Gravill | Main CFD Forum | 1 | March 28, 2007 20:16 |
