August 30, 2004, 05:55 |
CONTOURS LINES
do you know how to add contours lines in fluent. Thanking you in advance, Tania |
August 30, 2004, 06:58 |
Re: CONTOURS LINES
You can adjust the number of levels.
August 30, 2004, 07:51 |
Re: CONTOURS LINES
Actually, I want to present my results (for examples the pressure) as contours lines and filled colors at the same time.So, I would like to have the different colors separated with a line.
I didn't manage to do it in fluent. Either the results are presented as contour lines or filled with colors, but not the two at the same time. |
August 30, 2004, 08:11 |
Re: CONTOURS LINES
This cannot be done in Fluent, but I use Tecplot and you can have the contours multicolored and the lines any color you want.
August 30, 2004, 09:00 |
Re: CONTOURS LINES
Ok, thanks !
Best regards, Tania |
August 30, 2004, 13:29 |
Re: CONTOURS LINES
this can be done in fluent
First draw the countors with lines then go to display > scene munu click on overlays and click on apply now go to countrous and tick on filled and display cournts u will have both things at time but i suggest u to use tecplot. as it gives u more option to manipulate ur data Ragrads |
August 30, 2004, 14:49 |
Re: CONTOURS LINES
It works !!! thanks a lot !
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
Plotting Residuals | ata | OpenFOAM | 12 | July 8, 2011 02:50 |
coloured grid lines instead of contours | Matthias | FLUENT | 8 | December 10, 2008 19:09 |
Preconditioning and pressure contours | ganesh | Main CFD Forum | 2 | February 18, 2006 00:02 |
extension for liquid fraction contours | venugopal | FLUENT | 0 | June 11, 2004 01:27 |
